- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > Obvious problem symptoms to check for on TD5 engine? |
lohr500
Well no obvious symptoms of imminent terminal destruction, so despite the 209k Miles on the clock we bought it. No idea how much surgery it has had in the past but considering the mileage it drove really well. The TD5 sounded sweet as a nut and amazingly for an old JLR vehicle, everything appeared to work as it should. What could possibly go wrong
Need to do some research now into the Adventurer LE spec and see if we have found a rare beasty.
23rd Mar 2021 7:27pm |
