Home > Maintenance & Modifications > Should I replace my springs?
Leathers
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Galway Green
I’ve been told after a recent service that my 2008 110 CSW has a leaky shock so I’m investigating options. I assume I need to change the springs too? I think they’re all original but it’s only done 45k. I’d like to upgrade if it’s sensible but am not into too much bling and only really do road miles, a bit of country tracks and horse box towing. Seeking your wise words - on my second post, have posted in the new Defender area first by mistake! D’oh.
Post #889637 7th Mar 2021 2:11pm
RobKeay
Just about to change my springs. I am on 130k and they are completely knackered. I did the shocks ages ago. Not sure which springs to go for. I still want it to be the standard height. Just feel £100 a spring from Landrover is too much and £25 from britpart too cheap. Looking for a happy medium. OE spec.
Post #889641 7th Mar 2021 2:23pm
You could look for some new take-offs, although I guess they'll be harder to find these days. If your originals have lasted 130k miles though, perhaps the LR price isn't that bad? Darren
Post #889650 7th Mar 2021 3:22pm
Litch
"Just feel £100 a spring from Landrover is too much and £25 from britpart too cheap."
Don't dismiss the BP items as being too cheap.
I have had a set of OE spec BP fronts on for about 6-years now and they have been perfect with no sag or settling whatsoever. I removed them last year when I did a chassis change and they cleaned up as new which is more than can be said for many aftermarket springs which chip & rust within months.
So impressed that last year I fitted a pair of BP OE HD rears. ONE LIFE, GET IT!
Post #889666 7th Mar 2021 4:37pm
bear100
i replaced rusty original springs for new takes offs and fitted Fox shocks last year and the difference was night and day, totally transformed the ride, the Fox are a bit more than the standard or OME or Billstein etc but worth every penny.
I also fitted the airlifter bags inside the rear springs, my 110 is used for various things like expeditions where its fully laden, shooting with hardly any load, towing trailer or huge caravan etc and its made a huge improvement. 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #889671 7th Mar 2021 5:11pm
htb2
Wales
My originals are at 230,000 miles but really could do with changing. 110 Hicap always towing heavy Ifors.
Front winch dosn't help either
Post #889675 7th Mar 2021 5:30pm
I don't really understand why having a leaky damper makes you think the springs need changing. If they're ok, don't change them.
My 110 works hard, is always laden, is often towing, and has a heavy winch and is still on the original springs at 250,000 miles. Front dampers are original, rears are first replacements.
Post #889680 7th Mar 2021 6:07pm
Dinnu
The problem with defender springs is that where the coil terminates, there is a lot of metal to metal contact as the spring is compressed and less compressed. Most other car manufacturers reduce this issue by using coils that reduce in diameter towards the end, or simply terminate the coil without changing its pitch.
On newer Defenders, the end coils are just ground flat (with a change of pitch).
Earlier 90s and 110s has the ends flattened, so the coils that touch at its ends have a much wider contact area. Better design in my opinion, more expensive to manufacture of course. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #889697 7th Mar 2021 7:53pm
Leathers
Really useful, thanks guys. I was assuming that it would be efficient to change the springs at the same time as the shocks, but it sounds like they will have a lot of life left in them!
Post #889723 7th Mar 2021 10:22pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Yes, at 45k just change dampers and keep the OE springs. Thumbs Up
Post #889739 7th Mar 2021 11:35pm
spudfan
Ireland
My 1992 200 tdi 110 is still on it's origional springs. The origional shock absorbers were changed last year. I do not do any heavy towing.
Our 2008 Puma is on it's origional shocks and springs. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #889937 8th Mar 2021 7:05pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I've replaced shocks with new LR take offs but still on original springs (136k).
If springs ok leave alone and save money Thumbs Up
Post #890003 8th Mar 2021 9:40pm
Ianh
Call these guys , cabmasters, they have take off shocks and springs if you want them... or you may get a good price just for shocks if that’s all you want. https://cabmasters.com/product/special-off...-full-set/
Post #890022 8th Mar 2021 10:33pm
spudfan
Ireland
Just as an aside to the above.
The wife's suspension has not fared aswell...... 1982 88" 2.25 diesel
Post #890035 8th Mar 2021 11:07pm
