Home > In Car Electronics > Rear Permanent and Ignition Lives.....
mcma1
Quick one, as i understand there is the permanent purple and then the ignition green/white live to the rear wiper motor, but can I take a feed from each of these into a A/B blue sea fuse board to feed other circuits? Or is there a limit to what these can handle? I have the rear seat heaters, the alpine sub and 2 lazer spots to supply.
Thanks Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #882522 2nd Feb 2021 8:33am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
mcma, the loads you want to add seems like a lot of amps to add to an existing wire.
I'd use the ign live that's already there to switch a relay that feeds directly from the battery.
Post #882531 2nd Feb 2021 9:29am
The permanent live to the towing electrics is fused at 20amps, from memory, and the feed to the rear wiper will be a lot less. I can't imagine that either would be up to the job of seat heaters and a sub. It'd be far better to run a dedicated power supply for that kit. Darren
Post #882532 2nd Feb 2021 9:31am
mcma1
Yea, its was early to be thinking about electrics Laughing I think a heavy live from the battery into an ignition sense module and then feed A & B with those would be best. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #882534 2nd Feb 2021 9:31am
Martin
Site Admin
Why bother with the ignition sense, use the rear wiper ignition feed as the trigger.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #882554 2nd Feb 2021 11:04am
