Home > Puma (Tdci) > Glow plugs renewal advice
bear100
Hi all
My Puma has stated to be a bit on the lumpy side in the mornings with some white smoke,
So
I’ve decided to swap out the glow plugs (first set in 10 years) is this an easy DIY job for the driveway? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #878493 14th Jan 2021 6:44pm
hank
It's a DIY job provided the glow plugs come out and are not seized and snap off on you
Remove inlet manifold (could possibly skip this step not sure but would make things difficult)
Remove the four nuts securing the wiring to the glow plugs
Remove glow plugs
Reassemble
Recommend getting some penetrating fluid on them every day for a week or more leading up to the job. Possibly some heat when you try to release them. > 110 XS Double Cab
Post #878497 14th Jan 2021 7:06pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
If your doing it on the 2.4 puma (transit) engine the inlet manifold needs to be removed.
Take a look on YouTube Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #878501 14th Jan 2021 7:28pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Spray some releasing fluid on them for about a week before you do them. Try and remove them when the engine is warm. Get inlet manifold gaskets while you're at it. Take your time taking them out and you should be fine Thumbs Up
Post #878517 14th Jan 2021 9:22pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
I’ve found that lumpy running and white smoke on cold start is likely to be a leaky injector. The residual fuel rail pressure causes the injector to weep into the combustion chamber. This causes slow starting, uneven running and white smoke until the fuel is burnt off. Usually engine runs fine once fuel has been burnt off.
Maybe best to test glow plugs first. 2011 130 Utility Body
2005 110 Van
Post #878566 15th Jan 2021 9:47am
bear100
Thank for the tips Thumbs Up 2023 Defender L663 V8
Post #879175 17th Jan 2021 8:40pm
hank
Will be interested to hear how you got on as and when... > 110 XS Double Cab
Post #879615 19th Jan 2021 10:28pm
landy andy
Is it not worth testing them first whilst they are still fitted?
Post #879630 19th Jan 2021 11:33pm
