![]() | Home > Puma (Tdci) > Glow plugs renewal advice |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
It's a DIY job provided the glow plugs come out and are not seized and snap off on you
Remove inlet manifold (could possibly skip this step not sure but would make things difficult) Remove the four nuts securing the wiring to the glow plugs Remove glow plugs Reassemble Recommend getting some penetrating fluid on them every day for a week or more leading up to the job. Possibly some heat when you try to release them. > 110 XS Double Cab |
| Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970
If your doing it on the 2.4 puma (transit) engine the inlet manifold needs to be removed.
Take a look on YouTube Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
Spray some releasing fluid on them for about a week before you do them. Try and remove them when the engine is warm. Get inlet manifold gaskets while you're at it. Take your time taking them out and you should be fine
| mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 291
I’ve found that lumpy running and white smoke on cold start is likely to be a leaky injector. The residual fuel rail pressure causes the injector to weep into the combustion chamber. This causes slow starting, uneven running and white smoke until the fuel is burnt off. Usually engine runs fine once fuel has been burnt off.
Maybe best to test glow plugs first. 2011 130 Utility Body 2005 110 Van |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
Thank for the tips
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Will be interested to hear how you got on as and when... > 110 XS Double Cab
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
Is it not worth testing them first whilst they are still fitted?
| All times are GMT |
