Home > Off Topic > Cable/Rope sock
Page 2 of 2 <12
big ives
Chopperone wrote:
7 mm dia
7x 19 construction galvd
65 mtrs long
f & T one end
I own a Shooting ground ; The cable is used to raise my clay traps up/down my Tower for filling /altering height.
I have a 30m lift to the top.
Previously I have tried an Open ended sock - failed but then one of the top pulleys had failed.
Also tried splicing & taping with gaffer tape - that also failed - not sure what caused that to fail but I assume it was early on in the top pulley failing.
The idea of splicing in a section of dynamic rope appeals BUT it means losing the F&T end which fits into the winch drum.I need to research this bit .
I am looking for a solution that means I can readily change the cable ( which I do annually) without issue.
best to use wire rope snake, in your case it could be used many times see link below to give you an idea
https://lewismfg.com/product/lsg-snake-grips/ 2016 Discovery 4
1989 90 CSW V8 (fully rebuilt and running like a dream)
1996 defender tray back fully rebuilt/loaded for challenge events
Post #876692 6th Jan 2021 5:47pm
Chopperone
An adhesive heat shrink would/should have the flexibility - I will explore this.
Snake grip - good idea just not sure how that would work over the actual pulleys - IF the cable jumps out of the pulley there is no way I can get it back in without going up the Tower...
However I will look into this
Guy May your life be like toilet paper ; long & useful.
Post #876702 6th Jan 2021 6:15pm
Sulisuli
I would contact a specialist company who supply cable socks and ask their advice to ensure you get the correct item that is fit for purpose Thumbs Up last thing you want is a problem where the cable falls backwards or gets jammed and you have to climb up the tower. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #876753 6th Jan 2021 9:41pm
landy andy
I used to pull through stainless steel cables 10, 12, 14, and 16mm diameter cable through pulley blocks using these. Worked fantastically even underwater, and overhead. Can’t remember one not working if setup properly.
https://lewismfg.com/product/splicing-grip...del-lsg-o/
Post #876777 6th Jan 2021 10:57pm
Page 2 of 2 <12
