![]() | Home > Off Topic > Cable/Rope sock |
big ives Member Since: 24 Dec 2013 Location: Northern Ireland Posts: 128 ![]() ![]() |
best to use wire rope snake, in your case it could be used many times see link below to give you an idea https://lewismfg.com/product/lsg-snake-grips/ 2016 Discovery 4 1989 90 CSW V8 (fully rebuilt and running like a dream) 1996 defender tray back fully rebuilt/loaded for challenge events |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
An adhesive heat shrink would/should have the flexibility - I will explore this.
Snake grip - good idea just not sure how that would work over the actual pulleys - IF the cable jumps out of the pulley there is no way I can get it back in without going up the Tower... However I will look into this Cheers Guy May your life be like toilet paper ; long & useful. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
I used to pull through stainless steel cables 10, 12, 14, and 16mm diameter cable through pulley blocks using these. Worked fantastically even underwater, and overhead. Can’t remember one not working if setup properly.
https://lewismfg.com/product/splicing-grip...del-lsg-o/ |
