Home > Td5 > Is this a wading plug |
fly wheel timing hole for timing pin tool
4th Jan 2021 3:42pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
There are no wading plugs on a Td5.
4th Jan 2021 4:48pm |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 96 |
I'm pretty sure the one in the center of the picture is a wading plug, no?
4th Jan 2021 5:06pm |
You may be right about that! Perhaps I should delete my previous post...
4th Jan 2021 5:48pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
There are no “additional” wading plugs to put in place on a Td5 😆😉 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
5th Jan 2021 3:24am |
I believe it's not entirely necessary to plug it when wading. Does anyone know what size the timing hole is?
5th Jan 2021 6:15pm |
I’ve been doing serious off roading, wading, river crossing, swamp traversing and generally wet terrain driving for 30 + years, I have never put in a wading plug and never had any issues with the clutch or any bearings. 🤷♂️ 2010 Range Rover MkIII Autobiography Super Charged (Idris)
6th Jan 2021 3:47am |
The best use for the wadingplug is to keep the oil in if you have a little leak along your crankshaft seal.
Make sure you let the oil out regularly. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
6th Jan 2021 11:09am |
