![]() | Home > Tdi > Rebores |
Paroak Member Since: 16 Dec 2020 Location: South Wales Posts: 2 ![]() ![]() ![]() |
I need to get a 300 TDi rebored asap. Was going to go with +20 thou but my son said why not get it rebored to 2.8l? Without any research, (YET) is it worth it, is there any real gain in power, loss in reliability? I currently run through a LT77 box but have the option of changing to a R380. Are there any gains in either options? I intend to travel and want reliability above performance but wouldn't mind gaining in fuel economy if possible. Do I want the Earth? Yes. Can I have it? It is up to you!
![]() Paroak |
There's more to building a 2.8 than just re-boring it. They're also incredibly torquey and you'd really need to move to an R380 box for reliabilty. Darren
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
Were the bores measured for wear and found to be out of specifications to decide for a rebore?
I think the later LT77 were quite strong. My 1988 box is suffix E, which is not the strongest, but have a stronger reverse gear compared to suffix D! Only if I drive more backwards ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1249 ![]() ![]() ![]() |
The 2.8TGV which is what I assume you mean by boring out to 2.8 has a larger bore (ok you have that one ticked). Longer stroke crank (provides the extra torque to a certain extent) thus requires different pistons, rings, con rods, big ends, crank, bearings. The head and block if I remember correctly also have extra cooling channels (or rather they are not blocked off) but they may not be needed. There's also a different turbo if you're talking about getting a proper TGV setup. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
