![]() | Home > Td5 > Switched live |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I would take it from the reverse light switch connector under the tunnel or the speedo transducer.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
Fit an ATO ‘add a tap’ to the fuse box on the lighter feed supply. If it’s anything like the Puma the light feed fuse rating can be downgraded by 5A to account for a small extra load say 1A.
This is presuming you are wanting a switching load.. Run the wire under mats and or carpets and though a seat box rubber that’s existing on the seat box top. 1mm2 thin wall should be ideal. Then you’ve got the supply you need where you want it with good access and no chopping of waistline wiring.. Totally reversible too, plug and play fuse with easy access. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
See - https://www.defender2.net/forum/topic70342.html
. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
souster4 Member Since: 11 May 2014 Location: West midlands Posts: 153 ![]() ![]() |
Thanks guys. Great suggestions
Much appreciated. Merry Xmas all |
