Home > Off Topic > Power Supply for Engel fridge
kmac
My dog is allergic to kibble so I feed him raw meat. This usually comes in frozen form
So for camping etc. I got an Engel fridge so his food stays frozen till I need to defrost it.
I keep the fridge on in the house with the dog food in it, using an Engel branded far-east AC/DC converter
Today this power brick died. Sadly just a couple of months after the 12 month anniversary.
Questions: Any other alternatives other than just buying another power brick ( the Engel one is £50 plus delivery)
I am about to receive a bench power supply for radio electronics which I was thinking of using. The brick is rated as 13.8V DC 10Amps
My bench power supply can be set to output 13.8V DC and is rated for continuous supply at 25Amps so should do the job but wondering if anyone else has done this. (It also has a useful cigar lighter style connector rated at 10A)
Post #873094 15th Dec 2020 7:18pm
geobloke
Funny, I was only thinking of the same thing for he same reasons last week.
Found this: https://www.amazon.co.uk/RoyPow-Adapter-Ci...B019H2EQWY
It'd work. The only thing I would suggest is converting from standard cigarette plugs/sockets to the Hella Din version, much better connection.
Post #873116 15th Dec 2020 8:18pm
kmac
With a name like RoyPow I suspect that one is as robust as the Engle provided one - i.e. not very.
Good find, but I am looking to get a better quality power supply.
Edit: Actually looking at the ones it is compared to by Amazon, it is twice the price - may not speak to quality.
The power brick I have is actually 13.8V so would need to get one with the higher voltage
Post #873149 15th Dec 2020 9:29pm
macfrank
(sorry, can't help; I'm just surprised there are Engel fridges without both 12V and 110V/240V input; what model is it? just out of interest)
Post #874863 27th Dec 2020 9:33pm
kmac
The Engel only takes a 12V input. The power supply coverts 240v/110v AC to 12v DC so I can run the fridge in the house when I am not travelling.
Anyway, problem solved as I got one of these:
I also have a similar power supply with a digital volt and amp meter and at 13.8VDC, the fridge is quite frugal and only draws 2.8Amp on startup and then around 2Amps to maintain temps, with long periods of zero Amps
Post #874955 28th Dec 2020 7:59pm
jst
Does anyone know what plug is needed to run a 12v engel fridge.
35 or 45L one? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1067642 13th May 2025 10:31pm
macfrank
This is what's on mine. I think the fridge-side plug is Engel specific?
http://www.engel.store/en/12v-dc-connection-cable-51.html
Post #1067713 14th May 2025 5:27pm
You could probably get a small solar panel and controller set up if you needed to.
But for your intended use, I think you have the right solution already.
Portable solar systems for things like that are quite advanced now, ideal for powering lower consumption devices “in the field”.
Tend to be more readily available in the States than here, but the tech has come on quite a lot. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067722 14th May 2025 8:06pm
jst
Yep that's the one.how much!? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1067731 14th May 2025 9:35pm
macfrank
right :/ but you'll find them cheaper on ebay, even our local camping shop has it for around 25€
Post #1067732 14th May 2025 9:38pm
