Home > Puma (Tdci) > Cold Air Only !
PMU
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Cold Air Only !
I have a 2008 110 and today noticed that the temp needle goes to half way in about one minute ( normal an age) and there is only cold air blowing !
I am a tad worried as I had a 300Tdi Disco years ago and that was a precursor to the P gasket and had to have a new head !
I have been picking up on a couple of shoot the last two days but haven't done anything unusual as such.
any initial thoughts ? and can I drive in the meantime ?.
TIA
Post #871467 5th Dec 2020 8:29pm
Julie
Check coolant water level
Post #871470 5th Dec 2020 8:41pm
ickle
Is the heater valve actually operating and opening?
Is there an air lock in the hose (bleed valve on top heater hose)
HTH Keith
Post #871473 5th Dec 2020 8:44pm
LR90XS2011
low coolant would be my first check DEFENDER 90 TDCI XS,
Post #871478 5th Dec 2020 9:07pm
Greyman110
Funnily enough I noticed that my 2009 110 got to running temp quicky today!
I've been doing some work on it recently so have got to know how she runs quite well now. I did check the coolant and it was where it should be. I recently changed the heater valve and have bled the air a few times as well as doing the full process when you fill the coolant up.
I do have an issue that has been known to be caused by head gasket (going into limp mode when accelerating up hill in 6th) but the chem test came back clean so don't think thats the issue.
I did change the VCV today so thought that it could now be running more efficiently - it certainly sounded like it! But aside from that everything seemed normal.
I'll still keep driving mine but will just keep and eye on it. I do have a nanocom running live stats when I drive.
Post #871479 5th Dec 2020 9:08pm
PMU
Thanks all, will check the levels and have a dig around to see.
Thanks
Post #871521 6th Dec 2020 8:40am
PMU
Yep, low coolant..... now need to find where the leak is !
Post #871766 7th Dec 2020 11:34am
Julie
You indicated the most probable issue in your first post.
Water cooled EGR could also be an intersting detail to look at.
And some claim the cap not to be fully tight
Good luck Wink
Post #871839 7th Dec 2020 6:59pm
