![]() | Home > Puma (Tdci) > Cold Air Only ! |
| Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589
Check coolant water level
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1863
Is the heater valve actually operating and opening?
Is there an air lock in the hose (bleed valve on top heater hose) HTH Keith |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
low coolant would be my first check DEFENDER 90 TDCI XS,
I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 5th Dec 2020 9:08pm. Edited 1 time in total |
| Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327
Funnily enough I noticed that my 2009 110 got to running temp quicky today!
I've been doing some work on it recently so have got to know how she runs quite well now. I did check the coolant and it was where it should be. I recently changed the heater valve and have bled the air a few times as well as doing the full process when you fill the coolant up. I do have an issue that has been known to be caused by head gasket (going into limp mode when accelerating up hill in 6th) but the chem test came back clean so don't think thats the issue. I did change the VCV today so thought that it could now be running more efficiently - it certainly sounded like it! But aside from that everything seemed normal. I'll still keep driving mine but will just keep and eye on it. I do have a nanocom running live stats when I drive. |
| PMU Member Since: 13 Aug 2020 Location: Essex Posts: 33
Thanks all, will check the levels and have a dig around to see.
Thanks |
Yep, low coolant..... now need to find where the leak is !
You indicated the most probable issue in your first post.
Water cooled EGR could also be an intersting detail to look at. And some claim the cap not to be fully tight Good luck |
