![]() | Home > Maintenance & Modifications > Headlight and Upgraded suspension modifications |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1490 ![]() ![]() ![]() |
Hi,
LED lights. Top brand aftermarket LED lights from Trucklite or Nolden will be around £500 to £600 a pair. I believe the LR kit is Nolden lights. Consider lamps with a heated lens if you expect to drive it in snow. Unheated LEDs aren't hot enough to melt the snow and it builds up on the surface of the light. The LR suspension upgrade will also be eyewateringly expensive when compared to top brand parts - again probably the same ones - from a different supplier. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3676 ![]() ![]() ![]() |
firstly welcome to the forum
there are loads of threads on here about both the subjects you are interested in if you are looking for someone to do the work for you then you are close to IRB it may be worth trying to contact Ian, he is big on Facebook and also has an Instagram presence, DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Defcon20 Member Since: 28 Nov 2020 Location: Warwickshire Posts: 8 ![]() ![]() ![]() |
Thank you for the replies... I appreciate that the LE route is more expensive. You are correct that the LR headlights were made by Nolden and I had reviewed them, JW and Trucklite but wanted to review whether there was a more cost effective way of getting a pair of the LT units.
Thanks re note of IRB... is that a persons tag or a business? Thanks. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8375 ![]() ![]() ![]() |
https://irbdevelopments.com/
Ian business. Very knowledgeable and been around doing his thing for a long time with many a happy customer. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Many thanks - really appreciate everyone’s advice.
I seem to remember that the Nolden lights were supplied to LR by 4x4 Overlander. Take a look here: https://www.4x4overlander.com/?s=nolden&am...pe=product Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
You may struggle to get the first generation Nolden's that were used, I'm not sure they are readily available any more. I went for the 2nd gen ones and the cheapest were from Urban Automotive who give a small discount if you quote Angry Pumas.
Another vote for Ian @ IRB, he's based not far from Brum airport and has done all my modifications including his IRB SVE suspension kit which has given the best ride I've personally tried on a 90 ![]() |
Many thanks all. The 2md gen Noldens look like a good option with the DRL. Are they plug and play?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
I have the 1st Gen Noldens with sidelight, couldn’t fault them.
I actually prefer the 1st Gen design but the 2nd Gen no doubt are just as good. The main sticking point is they are significantly expensive, but considerable perhaps to many as an Xmas present like I did a few years ago. I’ve had them 4 or 5 years now without a single issue with them. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
They do have the same connector as your current Puma headlights but they're not quite what you'd call plug and play. The DRL will need to be wired in separately... with mine I already had a control unit fitted for the DRL's in the bumper so I linked in to that. (I had someone more competent than me fit mine... I don't like fiddling with anything electric!) |
