Home > Maintenance & Modifications > Headlight and Upgraded suspension modifications
Defcon20
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Yulong White
Hi there - I am new to the forum.
I am considering the following upgrades to a 2016 D90.
Landrover Suspension Upgrade: LRDSKIT90.
Headlights swapped for LR LED. LR069118
My questions:
1 Any idea on the cost of fitting the full suspension upgrade kit?
2. Is there a cheaper way of purchasing the headlights than £1000 each?
I know that there are less costly and equally performing alternatives, but would be interested in using LR OEM product if possible.
Many thanks.
Post #871060 3rd Dec 2020 1:08am
DSC-off
Hi,
LED lights. Top brand aftermarket LED lights from Trucklite or Nolden will be around £500 to £600 a pair. I believe the LR kit is Nolden lights.
Consider lamps with a heated lens if you expect to drive it in snow. Unheated LEDs aren't hot enough to melt the snow and it builds up on the surface of the light.
The LR suspension upgrade will also be eyewateringly expensive when compared to top brand parts - again probably the same ones - from a different supplier.
Post #871062 3rd Dec 2020 1:52am
LR90XS2011
firstly welcome to the forum
there are loads of threads on here about both the subjects you are interested in
if you are looking for someone to do the work for you then you are close to IRB it may be worth trying to contact Ian, he is big on Facebook and also has an Instagram presence, DEFENDER 90 TDCI XS,
Post #871065 3rd Dec 2020 7:35am
Defcon20
Thank you for the replies... I appreciate that the LE route is more expensive. You are correct that the LR headlights were made by Nolden and I had reviewed them, JW and Trucklite but wanted to review whether there was a more cost effective way of getting a pair of the LT units.
Thanks re note of IRB... is that a persons tag or a business? Thanks.
Post #871071 3rd Dec 2020 8:43am
jst
https://irbdevelopments.com/
Ian business. Very knowledgeable and been around doing his thing for a long time with many a happy customer. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #871073 3rd Dec 2020 9:00am
Defcon20
Many thanks - really appreciate everyone’s advice.
Post #871075 3rd Dec 2020 10:02am
I seem to remember that the Nolden lights were supplied to LR by 4x4 Overlander. Take a look here:
https://www.4x4overlander.com/?s=nolden&am...pe=product Darren
Post #871130 3rd Dec 2020 3:49pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
You may struggle to get the first generation Nolden's that were used, I'm not sure they are readily available any more. I went for the 2nd gen ones and the cheapest were from Urban Automotive who give a small discount if you quote Angry Pumas.
Another vote for Ian @ IRB, he's based not far from Brum airport and has done all my modifications including his IRB SVE suspension kit which has given the best ride I've personally tried on a 90 Thumbs Up
Post #871154 3rd Dec 2020 5:44pm
Defcon20
Many thanks all. The 2md gen Noldens look like a good option with the DRL. Are they plug and play?
Post #871716 7th Dec 2020 12:28am
I have the 1st Gen Noldens with sidelight, couldn’t fault them.
I actually prefer the 1st Gen design but the 2nd Gen no doubt are just as good.
The main sticking point is they are significantly expensive, but considerable perhaps to many as an Xmas present like I did a few years ago.
I’ve had them 4 or 5 years now without a single issue with them. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #871718 7th Dec 2020 1:10am
X4CAC
They do have the same connector as your current Puma headlights but they're not quite what you'd call plug and play. The DRL will need to be wired in separately... with mine I already had a control unit fitted for the DRL's in the bumper so I linked in to that.
(I had someone more competent than me fit mine... I don't like fiddling with anything electric!)
Post #871763 7th Dec 2020 11:21am
