Home > Maintenance & Modifications > Slick shift ?
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Slick shift ?
Any one fitted one ? , are they as good as they look ? , just thinking it might make a smoother entry when stiff .
Stew
Post #868417 19th Nov 2020 8:39pm
LR90XS2011
loads of threads on here regards the options and peoples views, here's 2
https://www.defender2.net/forum/topic74564...lick+shift
https://www.defender2.net/forum/topic66052...lick+shift DEFENDER 90 TDCI XS,
Post #868423 19th Nov 2020 8:55pm
stew 46
Thumbs Up Many thanks , found what I needed Thumbs Up
Post #868469 19th Nov 2020 11:25pm
Naks
Fitted one about 3 years ago - what a difference in the gear chages.
DO IT!!! Thumbs Up --
Post #868490 20th Nov 2020 7:59am
Re: Slick shift ?
stew 46 wrote:
... thinking it might make a smoother entry when stiff ...
I can't see how having a shorter throw would achieve that, myself.
Post #868500 20th Nov 2020 9:06am
Naks
the one major improvement over the OEM unit is that it feels & operates like a 'gated' unit - so you're never hunting around for the correct gear.
everything also shifts with minimal input - so now you can change gears with your fingers instead of having to use your whole arm. Laughing --
Post #868503 20th Nov 2020 9:13am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Love mine, fitted 40000 Km ago!
Slick Shift is not the right name. It feels more mechanical and precise. Smoother, it isn’t. It encourages you to drive more smoothly. Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT�s,
Recaro CS�s, anorak, wellingtons
Post #868566 20th Nov 2020 1:46pm
