![]() | Home > Maintenance & Modifications > Slick shift ? |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3676 ![]() ![]() ![]() |
loads of threads on here regards the options and peoples views, here's 2
https://www.defender2.net/forum/topic74564...lick+shift https://www.defender2.net/forum/topic66052...lick+shift DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Fitted one about 3 years ago - what a difference in the gear chages.
DO IT!!! ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
I can't see how having a shorter throw would achieve that, myself. |
the one major improvement over the OEM unit is that it feels & operates like a 'gated' unit - so you're never hunting around for the correct gear.
everything also shifts with minimal input - so now you can change gears with your fingers instead of having to use your whole arm. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Love mine, fitted 40000 Km ago!
Slick Shift is not the right name. It feels more mechanical and precise. Smoother, it isn’t. It encourages you to drive more smoothly. ![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
