Home > Puma (Tdci) > Removing slam panel on a tdci
Dinnu
Checking with you guys on how to remove the slam panel on a tdci? To be honest I have not tried, but it looks like it is fixed to the mudguards with studs. Do the mudguards need to be separated for the slam panel to come off, or the studs can come off? Are the studs installed in some captive nuts on the mudguards? Mine is with ac, so no crossbracing if that makes a difference.
Thanks for any advise.
https://www.lrworkshop.com/diagrams/land-r...ease_44831 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866798 11th Nov 2020 7:23pm
Bluest
There are studs fixed into the wings, I don't think they can be easily removed. To remove the slam panel I would think it would be possible to loosen enough bolts so the wing studs can be gently persuaded out of the way by pushing the wings aside. 2007 110 TDCi Station Wagon XS
Post #866804 11th Nov 2020 7:43pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Easiest way is to use the two-nut method to remove the studs while the slam panel is in place (with the hood supported by something else), and then replace them with bolts on reassembly
Two Nut method:
I didn't take pictures of exactly that work, but here you can see the studs and panel removed from when I changed my intercooler:
 Roaming around 🇳🇴🇨🇭
Post #866811 11th Nov 2020 8:08pm
Dinnu
Thank you.
Yes DS, I understand the 2 nut method. Appreciate going the extra mile to attach a video.
Good to see that it is doable.
Thank you guys for your feedback. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866822 11th Nov 2020 8:47pm
Dinnu
Probably I will strap the bonnet to the spare wheel carrier on rear door. Less likely to accidentally knock the temporary bonnet prop out of place. Bonnet is quite heavy with serious consequences if it falls on my head. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866823 11th Nov 2020 8:49pm
