![]() | Home > Puma (Tdci) > Removing slam panel on a tdci |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
Checking with you guys on how to remove the slam panel on a tdci? To be honest I have not tried, but it looks like it is fixed to the mudguards with studs. Do the mudguards need to be separated for the slam panel to come off, or the studs can come off? Are the studs installed in some captive nuts on the mudguards? Mine is with ac, so no crossbracing if that makes a difference.
Thanks for any advise. https://www.lrworkshop.com/diagrams/land-r...ease_44831 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Easiest way is to use the two-nut method to remove the studs while the slam panel is in place (with the hood supported by something else), and then replace them with bolts on reassembly
Two Nut method: I didn't take pictures of exactly that work, but here you can see the studs and panel removed from when I changed my intercooler: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Roaming around 🇳🇴🇨🇠|
Thank you.
Yes DS, I understand the 2 nut method. Appreciate going the extra mile to attach a video. Good to see that it is doable. Thank you guys for your feedback. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Probably I will strap the bonnet to the spare wheel carrier on rear door. Less likely to accidentally knock the temporary bonnet prop out of place. Bonnet is quite heavy with serious consequences if it falls on my head. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
