Home > In Car Electronics > Max load on the interior light 10 AS?
mcma1
I have searched and found lots of clips of info. Could you extend the current 110 to have 4 (in total) of the standard headlining lights running together using the normal candle light bulbs??
On the last build i did have 4 door lights on a separate circuit but i was trying to make this a bit easier as all the light are in the rear.
Also some people seem to solder direct to each terminal, are we talking about the tabs ether side on the bulb holder?
 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #865489 5th Nov 2020 8:36am
rallysteve
How many interior lights are there on a Discovery 1? You could use that as a further guide as they also use the 10AS
Post #865507 5th Nov 2020 10:47am
mcma1
Thanks Steve, must try to find out. Pretty sure a few guys here have added a third light direct to the 110. I am hoping to add 2 x 5w bulbs so an extra 5w. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #865514 5th Nov 2020 11:12am
Martin
Site Admin
Do you want to keep them as incandescent bulbs rather than LED?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #865515 5th Nov 2020 11:15am
mcma1
Ideally yes. Or can I replace the bulbs with Led but with warm white? Will they dim out then? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #865516 5th Nov 2020 11:23am
You can buy some very nice warm white LED's and they dim in exactly the same way as the original bulbs. I bought these ones from Conrad Electronics and whilst not cheap, they give a much improved light:
https://www.conrad-electronic.co.uk/ce/en/...AREA_22519 Darren
Post #865520 5th Nov 2020 11:48am
mcma1
Thanks Darren
Pretty if was you I seen add the third light?
Is that link working for you? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #865523 5th Nov 2020 12:05pm
Yeah, I've added a third light over the middle seats.
The link works ok although I've just noticed that they're out of stock. I guess they might be available elsewhere. Darren
Post #865525 5th Nov 2020 12:15pm
mcma1
Post #865527 5th Nov 2020 12:18pm
This might help:
 Darren
Post #865528 5th Nov 2020 12:21pm
mcma1
It mad what you find when you dig into the spares Laughing
These appear to fade ok. Strange thing is I took them out of the last 110 as they would have a glow but seem ok in this one. Just missing a w5w type but can pick them up in Halfords.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #865531 5th Nov 2020 12:44pm
hank
These are nice. Reasonably priced, look OEM as they are warm white, dimmable and shine 360 degrees in the enclosure
https://www.ebay.co.uk/itm/183005182692 > 110 XS Double Cab
Post #865888 7th Nov 2020 2:27pm
