![]() | Home > In Car Electronics > Max load on the interior light 10 AS? |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
I have searched and found lots of clips of info. Could you extend the current 110 to have 4 (in total) of the standard headlining lights running together using the normal candle light bulbs??
On the last build i did have 4 door lights on a separate circuit but i was trying to make this a bit easier as all the light are in the rear. Also some people seem to solder direct to each terminal, are we talking about the tabs ether side on the bulb holder? ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
How many interior lights are there on a Discovery 1? You could use that as a further guide as they also use the 10AS
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks Steve, must try to find out. Pretty sure a few guys here have added a third light direct to the 110. I am hoping to add 2 x 5w bulbs so an extra 5w. Andy
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
Do you want to keep them as incandescent bulbs rather than LED?
Ideally yes. Or can I replace the bulbs with Led but with warm white? Will they dim out then? Andy
You can buy some very nice warm white LED's and they dim in exactly the same way as the original bulbs. I bought these ones from Conrad Electronics and whilst not cheap, they give a much improved light:
![]() Click image to enlarge https://www.conrad-electronic.co.uk/ce/en/...AREA_22519 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks Darren
Pretty if was you I seen add the third light? Is that link working for you? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Yeah, I've added a third light over the middle seats.
![]() Click image to enlarge The link works ok although I've just noticed that they're out of stock. I guess they might be available elsewhere. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Are they just 239 bulbs?? Andy
This might help:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
It mad what you find when you dig into the spares
![]() These appear to fade ok. Strange thing is I took them out of the last 110 as they would have a glow but seem ok in this one. Just missing a w5w type but can pick them up in Halfords. ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363 ![]() ![]() ![]() |
These are nice. Reasonably priced, look OEM as they are warm white, dimmable and shine 360 degrees in the enclosure
https://www.ebay.co.uk/itm/183005182692 > 110 XS Double Cab |
