![]() | Home > In Car Electronics > Indicator Issues on driver's side |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3640 ![]() ![]() ![]() |
Left and right circuits are independent, and have their own fuse. Maybe can check fuses first, under steering wheel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
nick.bw Member Since: 26 Oct 2020 Location: Essex Posts: 77 ![]() ![]() ![]() |
Oh. Thanks. Do you.know which fuse to check? Thanks. Nick.
two fuse one for Indicator and one for hazard fuse 21-31 check lamp holders for corrosion and failing do to bad contact
Thanks all.
Side, Front and Rear indicators have been off, cleaned and put back on. If i still have the issue i will swap light from right to left. Seeing as i dont have a fuse per side, it can not really be the fuses causing me issues. Thanks Nick |
If its all that side that your having problem with have a look at steering wheel switch also do you same problem with hazard
yep, had the issue with hazards on.
Because its intermittent, its not an issue at the moment while its on the drive. thanks DoresetSmith! |
I check manual, indeed 2 fuses supply the Switch-Hazard warning S121. Circuits are of course separate after this switch.
Could be the hazard switch. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
If you have the towing electrics. Check that the back of the socket is clean and dry, you will have to remove the socket and pull the boot back, its normal to find it full of damp silt. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
