Home > In Car Electronics > Indicator Issues on driver's side
nick.bw
United Kingdom 2014 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi all
I have a 110 puma (2014) and today noticed that my indicators on the driver's side are intermittently working. Now is it normal for all the indicators to.stop on one side of there is a bulb fault? They seem to be intermittently working at the moment. I have purchased new indicator bulbs for the front. The rear and side indicators are LED.
Anything people can recommend to check or look at before the bulbs arrive this week?
Nick
Post #863563 26th Oct 2020 6:11am
Dinnu
Left and right circuits are independent, and have their own fuse. Maybe can check fuses first, under steering wheel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #863569 26th Oct 2020 8:14am
nick.bw
Oh. Thanks. Do you.know which fuse to check? Thanks. Nick.
Post #863574 26th Oct 2020 9:07am
dorsetsmith
two fuse one for Indicator and one for hazard fuse 21-31 check lamp holders for corrosion and failing do to bad contact
Post #863587 26th Oct 2020 10:38am
nick.bw
Thanks all.
Side, Front and Rear indicators have been off, cleaned and put back on.
If i still have the issue i will swap light from right to left.
Seeing as i dont have a fuse per side, it can not really be the fuses causing me issues.
Thanks
Nick
Post #863600 26th Oct 2020 11:51am
dorsetsmith
If its all that side that your having problem with have a look at steering wheel switch also do you same problem with hazard
Post #863607 26th Oct 2020 12:23pm
nick.bw
yep, had the issue with hazards on.
Because its intermittent, its not an issue at the moment while its on the drive.
thanks DoresetSmith!
Post #863611 26th Oct 2020 12:39pm
Dinnu
I check manual, indeed 2 fuses supply the Switch-Hazard warning S121. Circuits are of course separate after this switch.
Could be the hazard switch. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #863621 26th Oct 2020 1:55pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Re: Indicator Issues on driver's side
nick.bw wrote:
Hi all
Nick
If you have the towing electrics. Check that the back of the socket is clean and dry, you will have to remove the socket and pull the boot back, its normal to find it full of damp silt. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #863639 26th Oct 2020 4:09pm
