Home > Td5 > TD5 Throttle Problems |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6479 |
Remove the pedal and check what part number is fitted.
Also the part number of the ECU, you may have a mis-match between the ECU type and the pedal type. It's a 2003 so should be an NNN ECU with a 3-track pedal, but who knows what it's ended up with from the MOD when sold, or what spec the MOD had in the first place. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Oct 2020 12:36pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 572 |
Or just switch to 2 way pedal first - with diagnostics in engine ECU. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
20th Oct 2020 1:03pm |
agw123 Member Since: 19 Mar 2018 Location: Sussex Posts: 4 |
Hi Martin,
Thanks for your reply. The pedal part number is G2G29AF98481. I cant seem to find any info on that anywhere, do they have individual part numbers for each pedal? Where do I find what type the ECU is? The label on it gives a number starting with NNW***, is that what I'm looking for? Thanks |
30th Oct 2020 11:16am |
On the ECU there will be a part number starting MSB or NNN (not NNW)
The pedal should have a yellow sticker with something starting SLC 1988 90 Td5 NAS soft top 2015 D90 XS SW |
30th Oct 2020 11:22am |
Found the pedal part number, but as far as I can see the ECU code starts with NNW. I've attached some photos, is that the right code?
Click image to enlarge Click image to enlarge |
30th Oct 2020 4:23pm |
