![]() | Home > Td5 > TD5 Throttle Problems |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
Remove the pedal and check what part number is fitted.
Also the part number of the ECU, you may have a mis-match between the ECU type and the pedal type. It's a 2003 so should be an NNN ECU with a 3-track pedal, but who knows what it's ended up with from the MOD when sold, or what spec the MOD had in the first place. ![]() ![]() |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
Or just switch to 2 way pedal first - with diagnostics in engine ECU. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
agw123 Member Since: 19 Mar 2018 Location: Sussex Posts: 4 ![]() ![]() |
Hi Martin,
Thanks for your reply. The pedal part number is G2G29AF98481. I cant seem to find any info on that anywhere, do they have individual part numbers for each pedal? Where do I find what type the ECU is? The label on it gives a number starting with NNW***, is that what I'm looking for? Thanks |
On the ECU there will be a part number starting MSB or NNN (not NNW)
The pedal should have a yellow sticker with something starting SLC ![]() ![]() |
Found the pedal part number, but as far as I can see the ECU code starts with NNW. I've attached some photos, is that the right code?
![]() Click image to enlarge ![]() Click image to enlarge |
