![]() | Home > Puma (Tdci) > Intermittent Starting Issue 2.4 TDCI |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727 ![]() ![]() ![]() |
You almost certainly have the intermittent broken solder joint on the instrument pack connector. You can do a bypass or repair as per my previous post here: https://www.defender2.net/forum/post814212.html#814212 ![]() ![]() |
MGRGPGBG Member Since: 19 Dec 2017 Location: New York Posts: 70 ![]() ![]() ![]() |
I will review but I should have noted in the initial post that I had Bell Auto do an immobilizer delete in my software. This issue also happened before the delete occurred...I had hoped the problem was the immobilizer but will look into your post - Thank you
Following up to see if anyone else has had this issue. I tried the fixes mentioned in the above reply but unfortunately that did not solve the problem. Thanks again!
Update - after a few months of testing I seem to have located the issue. Whenever the starting issue occurred the relays were mounted on the metal tabs in the seatbox. I had pulled them from these tabs and they were just hanging in the seatbox area so I would be able to run a test light probe or jumper wire, etc. Once I pulled the relay off the tabs the issue went away. I have a feeling that somehow the wall of the seatbox got hot from my exhaust and the relay was affected by the heat, expanded, and did not make a good contact. Explains why the issue only happens when the truck was warmed up. I plan on fitting some new metal connections and relay sockets on to make sure everything has a good contact. Most likely just leave them in the seatbox as they are now and not on the tab mounts.
