Home > Td5 > Fuel lines
Kris614
Wales 2003 Defender 110 Td5 XS DCPU Keswick Green
Fuel lines
Evening all,
Whilst fitting a new cross member on my 110 Td5 one of the fuel pump pipes number 6 has snapped (see pics) anyone know where I can get one? Hard work trying to find it!
Any help would be great. Closer to Newport\Cardiff the better
Thank you
Kris
Post #859964 5th Oct 2020 7:04pm
The broken part is an integral part of the pump assembly and as far as I know is not available as a separate part. Sad
Post #859967 5th Oct 2020 7:26pm
Kris614
Found one...
Post #859970 5th Oct 2020 7:40pm
dorsetsmith
if its peace off the end fuel line ( yes it is) make shore you do not loess or brake the clip that lock it in place
only supplied with pump
7.89mm ID6 Fuel Line Hose Straight Quick Release Male are the ones for the td5 fuel pump
one one the right
Post #859971 5th Oct 2020 7:41pm
Ah, the broken bit is still stuck.in the tank unit, I mistook that for a broken fitting on the sender. Sorry.
Post #860005 5th Oct 2020 10:27pm
dorsetsmith
TD5 Fuel line repair pump end
Post #860263 7th Oct 2020 1:52pm
