![]() | Home > Td5 > Fuel lines |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
The broken part is an integral part of the pump assembly and as far as I know is not available as a separate part.
Kris614 Member Since: 30 Nov 2018 Location: Cwmbran Posts: 14 ![]() ![]() ![]() |
Found one...
![]() Click image to enlarge if its peace off the end fuel line ( yes it is) make shore you do not loess or brake the clip that lock it in place only supplied with pump ![]() Click image to enlarge 7.89mm ID6 Fuel Line Hose Straight Quick Release Male are the ones for the td5 fuel pump ![]() Click image to enlarge one one the right |
Ah, the broken bit is still stuck.in the tank unit, I mistook that for a broken fitting on the sender. Sorry.
![]() Click image to enlarge TD5 Fuel line repair pump end |
