Home > Technical > Electrical/heater 12v acc socket issue
I was just driving home in the td5 had my phone charger in on the acc socket,
Turned the heater fan on and when it was on full speed 3 the 12v socket went off.
Put it on speed 2 and the 12v socket came on, but no fan at all?
Anybody had this before?
All other electrics are fine, horn, lights, wipers, radio, all good.
Any help please? QRZ 2e0vpf
Post #859956 5th Oct 2020 6:23pm
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
My TD5 only has 2 fan speeds unless you count off a a speed
Post #859958 5th Oct 2020 6:37pm
dorsetsmith
have a look at earth for both
heater switch just in side dash left hand side on the switch
acc socket on body
try ruing independent earth
Post #859961 5th Oct 2020 6:53pm
Good point and exactly what you said Laughing
Thanks DorsetSmith, i do suspect it may be an earthing issue, though I didn’t know whether a resistor issue may be a factor! QRZ 2e0vpf
Post #859963 5th Oct 2020 7:00pm
dorsetsmith
speed 2 it bypass the resistor
Post #859969 5th Oct 2020 7:39pm
HardCharger
Sounds like your ignition switch may be on its way out
Post #860013 6th Oct 2020 3:03am
