![]() | Home > Technical > Electrical/heater 12v acc socket issue |
| drakes Member Since: 09 Oct 2009 Location: Consett Posts: 115
My TD5 only has 2 fan speeds unless you count off a a speed
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
have a look at earth for both
heater switch just in side dash left hand side on the switch acc socket on body try ruing independent earth Last edited by dorsetsmith on 5th Oct 2020 6:11pm. Edited 1 time in total |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Good point and exactly what you said Thanks DorsetSmith, i do suspect it may be an earthing issue, though I didn’t know whether a resistor issue may be a factor! QRZ M8VPF |
speed 2 it bypass the resistor
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 825
Sounds like your ignition switch may be on its way out
| All times are GMT |
