![]() | Home > Technical > Defender TD5 Leak ball/swivel front axle |
3.5 hrs? If the ball will be replaced I think that is OK.
The problem is you never can say if it will be an easy job or that you have to fight every bolt. Personally as my labor doesn't cost anything, just time. ![]() Just a seal can be done in an hour I think. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
charisme1 Member Since: 23 Oct 2019 Location: Paris Posts: 43 ![]() ![]() |
Hi Thanks for the reply. Garage confirmed that swivel, bearings and ball are OK. They have only to change the seals (cheap parts). What worries me is the 3.5 hours labour for one wheel. Do you think it’s excessive or that’s what it needs ?
Best ! Julien |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
I have had one seal replaced under warranty.
LR garage allowed 1.25 hours I think, and it looked like they replaced it as Blackwolf described. 3.5 hours is certainly excessive for changing one seal. |
If the total bill is €105 euro. I wouldn't complain to much.
The seal is about €20,- I guess and a bag grease €7-10,- That leaves €70 for labor. I don't think they will work 3 hours for that. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
