Home > Technical > Defender TD5 Leak ball/swivel front axle
Page 2 of 2 <12
charisme1
France
Hi All
Garage confirmed that swivel and bearings are OK. Only the ball joints to replace. They are not expansive 105 € but asking for 3hours and a half labour.
To those how repaired by themselves or sent to garage. Do you think that 3.5h labour for one joint ball is exagerated ?
Your feedback is more than welcome.
Merci beaucoup !
Post #862701 20th Oct 2020 11:14pm
roel
3.5 hrs? If the ball will be replaced I think that is OK.
The problem is you never can say if it will be an easy job or that you have to fight every bolt.
Personally as my labor doesn't cost anything, just time. Very Happy I would probably only replace the seal after checking how the ball looks. The ball does not have to be 100% smooth but there should not be any holes through the shiny layer.
Just a seal can be done in an hour I think. Roel
2003 90 Td5 (2009-now)
Post #862762 21st Oct 2020 9:28am
charisme1
France
Hi Thanks for the reply. Garage confirmed that swivel, bearings and ball are OK. They have only to change the seals (cheap parts). What worries me is the 3.5 hours labour for one wheel. Do you think it’s excessive or that’s what it needs ?
Best !
Julien
Post #862763 21st Oct 2020 9:38am
Balvaig
I have had one seal replaced under warranty.
LR garage allowed 1.25 hours I think, and it looked like they replaced it as Blackwolf described.
3.5 hours is certainly excessive for changing one seal.
Post #862781 21st Oct 2020 10:56am
roel
If the total bill is €105 euro. I wouldn't complain to much.
The seal is about €20,- I guess and a bag grease €7-10,-
That leaves €70 for labor. I don't think they will work 3 hours for that. Mr. Green Roel
Post #862855 21st Oct 2020 5:56pm
Page 2 of 2 <12
