Home > Technical > ABS Ring |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2231 |
No it's built/machined in to the driveshaft. What is the issue with the existing ring? Are you sure the issue lies with the ring itself? Have you checked the sensor gap?
Click image to enlarge > 110 XS Double Cab > Instagram @simonlanemind |
2nd Oct 2020 10:42am |
Few things to check here
https://www.defender2.net/forum/topic69005.html > 110 XS Double Cab > Instagram @simonlanemind |
2nd Oct 2020 10:50am |
sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148 |
Hi Thanks for reply .Yes I had the abs sensor replaced .First with after market then secondly with Land rove part to make sure.Also had auto spark check abs pump etc .
Click image to enlarge rear ABS ring |
2nd Oct 2020 12:29pm |
Found it it also 364 !!.Thanks
2nd Oct 2020 5:29pm |
check wiring, abs sensor. too start with before the price thing
on my phone you have wheel bearing all good |
2nd Oct 2020 6:00pm |
Hi Update on this saga . Changed the abs ring and its still the same . Getting a reading from all 4 wheels but the one with new ring different . Still get the abs light and grinding noise. U have now had the sensor changed twice and now the ring . Next step is to get the auto spark back .
1st Nov 2020 11:00am |
