![]() | Home > Technical > ABS Ring |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2325 ![]() ![]() ![]() |
No it's built/machined in to the driveshaft. What is the issue with the existing ring? Are you sure the issue lies with the ring itself? Have you checked the sensor gap?
![]() Click image to enlarge > 110 XS Double Cab |
Few things to check here
https://www.defender2.net/forum/topic69005.html > 110 XS Double Cab |
sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148 ![]() ![]() |
Hi Thanks for reply .Yes I had the abs sensor replaced .First with after market then secondly with Land rove part to make sure.Also had auto spark check abs pump etc .
![]() Click image to enlarge rear ABS ring |
Found it it also 364 !!.Thanks
check wiring, abs sensor. too start with before the price thing
on my phone you have ![]() wheel bearing all good |
Hi Update on this saga . Changed the abs ring and its still the same . Getting a reading from all 4 wheels but the one with new ring different . Still get the abs light and grinding noise. U have now had the sensor changed twice and now the ring . Next step is to get the auto spark back .
