Home > Technical > Defender Td5 ABS Issues |
Wheel bearings was always a favourite. Darren
28th Sep 2020 8:52pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2049 |
Yup. Fronts are new(ish, sub 5k, Timken, no play) swivels have zero play as well Instagram @defender_ventures
Empire Tuning - Agent |
28th Sep 2020 9:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16809 |
Wiring fault, high impedance connection (always a popular problem with f.o.s sensor on the Disco2).
28th Sep 2020 9:23pm |
Ahhh handy! Whats the fix? Cut back as far into the loom as possible and run new line? Instagram @defender_ventures
29th Sep 2020 4:49am |
On the Disco2 there was a service action to replace the entire sensor harness from the F.O.S sensor back to the SLABS ECU with a continuous harness, to replace the connector mounted on the F.O.S inner wing. I had to do this within weeks of the warranty expiring on my '02 D2 due to the three amigos.
Ironically last year I had to replace the F.O.S sensor and you cannot get replacement sensors with the extended harness any more, so I ended up reconnecting the original and previously disconnected harness and reinstating the supposedly troublesome connector on the inner wing. It would probably be sensible to do a continuity and impedance check, and a visual inspection, of the wiring from the sensor connector back to the ABS controller, it might show something suspect. I imagine that you have checked that the clearance between the sensors and the inductor rings on the hubs are correct? |
29th Sep 2020 8:05am |
TVR Tommy Member Since: 26 Nov 2013 Location: Bucks Posts: 179 |
Check the earth to ABS control unit under the seat, nut could be loose.
Edited to say: I read your whole post (should try that first) and probably not an earth fault with the error you describe |
29th Sep 2020 9:23am |
Thank you both. Ill check both.
Itll be fun considereing where the Defender ABS unit is Instagram @defender_ventures Empire Tuning - Agent |
30th Sep 2020 4:41am |
