![]() | Home > Technical > Defender Td5 ABS Issues |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Wheel bearings was always a favourite. Darren
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Yup. Fronts are new(ish, sub 5k, Timken, no play) swivels have zero play as well
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18040
Wiring fault, high impedance connection (always a popular problem with f.o.s sensor on the Disco2).
Ahhh handy! Whats the fix? Cut back as far into the loom as possible and run new line?
On the Disco2 there was a service action to replace the entire sensor harness from the F.O.S sensor back to the SLABS ECU with a continuous harness, to replace the connector mounted on the F.O.S inner wing. I had to do this within weeks of the warranty expiring on my '02 D2 due to the three amigos.
Ironically last year I had to replace the F.O.S sensor and you cannot get replacement sensors with the extended harness any more, so I ended up reconnecting the original and previously disconnected harness and reinstating the supposedly troublesome connector on the inner wing. It would probably be sensible to do a continuity and impedance check, and a visual inspection, of the wiring from the sensor connector back to the ABS controller, it might show something suspect. I imagine that you have checked that the clearance between the sensors and the inductor rings on the hubs are correct? |
| TVR Tommy Member Since: 26 Nov 2013 Location: Bucks Posts: 194
Check the earth to ABS control unit under the seat, nut could be loose.
Edited to say: I read your whole post (should try that first) and probably not an earth fault with the error you describe |
Thank you both. Ill check both.
Itll be fun considereing where the Defender ABS unit is |
| All times are GMT |
