- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
                | umbertob
   | | Park Brake - Service Mode Manual Activation / Deactivation |  |
 Not sure if this was posted before, from the workshop manual. You - or your mechanic - would follow this procedure if replacing rear brake pads and/or brake discs without LR diagnostics (which has a routine to do this automatically), to release and set the EPB in service mode, and back into regular operating mode after you are done servicing the rear brakes.
 https://app.box.com/s/o9da83bhrxul9aniqk6j28ybx6d207j4
                |  22nd Sep 2020 11:59pm |  |
                | Q86ARR
 | You also need to be aware that as new Defender does not have a brake booster, it has a brake booster module (BBM) this also needs to be put in service mode before ANY brake repairs are carried out |
                |  10th Oct 2020 8:19am |  |
	    | Posting Rules
                   | You cannot post new topics in this forum You cannot reply to topics in this forum
