Home > General & Technical (L663) > Park Brake - Service Mode Manual Activation / Deactivation
umbertob
United States
Not sure if this was posted before, from the workshop manual. You - or your mechanic - would follow this procedure if replacing rear brake pads and/or brake discs without LR diagnostics (which has a routine to do this automatically), to release and set the EPB in service mode, and back into regular operating mode after you are done servicing the rear brakes.
https://app.box.com/s/o9da83bhrxul9aniqk6j28ybx6d207j4
Post #857530 23rd Sep 2020 12:59am
Q86ARR
You also need to be aware that as new Defender does not have a brake booster, it has a brake booster module (BBM) this also needs to be put in service mode before ANY brake repairs are carried out
Post #860781 10th Oct 2020 9:19am
