Home > Td5 > Engine cover |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2507 |
Probably the classic, its a Defender so charge what you like.
My wife had a Discovery 2 in the past , i cant think that there is a difference. |
18th Sep 2020 7:13pm |
Defender and disco are definitely the same, I have a spare one off a disco that I plan on modifying before fitting - but it will fit as standard straight off a disco 2002 90 Td5 Station Wagon
19th Sep 2020 7:54am |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 770 |
Excellent, thank you
19th Sep 2020 9:15am |
thinman21 Member Since: 27 Jan 2020 Location: Nottingham Posts: 11 |
Guess we could do with a parts interchange list somewhere so we know which Disco parts fit a Defender so we can check if they're cheaper.
Must be more than the engine cover thats a match. |
21st Sep 2020 7:00am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6026 |
Same with the in tank fuel pumps...
Disco used to be much cheaper than defender (don't know if this is still the case) Just get a disco one, unclip the float arm and swap it with the float arm off of your defender pump job done |
21st Sep 2020 10:37am |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 507 |
Just bought a discovery 2 MOT failure for parts, what axle parts are swappable, rear shafts and front and rear diffs is all I can think of. To go onto a 05 110 td5?
21st Sep 2020 6:13pm |
Yeah that's about it for the axles I believe.
There's a few things I can think of off the top of my head but can't say with 100% accuracy Air box is the same apart from the air in elbow which can be swapped for the defender one Front row interior lights Headlamp level switch 3rd brake light Heated front window switch Heated seat switches Swan neck tow ball is a good upgrade as it gives you more clearance with the spare (especially for alko friction stabilisers) Gearbox* Transfer box* (both need defender parts to swap onto them) Bonnet stay Exhaust downpipe Steering box I think 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Sep 2020 7:07pm |
Thanks Grafty, pretty much what I thought but no head lamp level on my defender.
Transfer box does not have the selector casting. Rad similar but one pipe outlet different. |
21st Sep 2020 7:48pm |
