![]() | Home > Td5 > Engine cover |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2673 ![]() ![]() ![]() |
Probably the classic, its a Defender so charge what you like.
My wife had a Discovery 2 in the past , i cant think that there is a difference. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Defender and disco are definitely the same, I have a spare one off a disco that I plan on modifying before fitting - but it will fit as standard straight off a disco
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1003 ![]() ![]() |
Excellent, thank you
thinman21 Member Since: 27 Jan 2020 Location: Nottingham Posts: 11 ![]() ![]() ![]() |
Guess we could do with a parts interchange list somewhere so we know which Disco parts fit a Defender so we can check if they're cheaper.
Must be more than the engine cover thats a match. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6207 ![]() ![]() ![]() |
Same with the in tank fuel pumps...
Disco used to be much cheaper than defender (don't know if this is still the case) Just get a disco one, unclip the float arm and swap it with the float arm off of your defender pump job done |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
Just bought a discovery 2 MOT failure for parts, what axle parts are swappable, rear shafts and front and rear diffs is all I can think of. To go onto a 05 110 td5?
Yeah that's about it for the axles I believe.
There's a few things I can think of off the top of my head but can't say with 100% accuracy Air box is the same apart from the air in elbow which can be swapped for the defender one ![]() Front row interior lights Headlamp level switch 3rd brake light Heated front window switch Heated seat switches Swan neck tow ball is a good upgrade as it gives you more clearance with the spare (especially for alko friction stabilisers) Gearbox* Transfer box* (both need defender parts to swap onto them) Bonnet stay Exhaust downpipe Steering box I think 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Thanks Grafty, pretty much what I thought but no head lamp level on my defender.
Transfer box does not have the selector casting. Rad similar but one pipe outlet different. |
