Home > Puma (Tdci) > Chassis clip help please.
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
Hi everyone.
I have finally got my 2011 chassis blasted and painted so reassembly can start soon.
I wonder if anyone can help please with part numbers for these plastic clips which locate brake lines and breather lines to the chassis. They are hard and brittle so break when removed as you can’t get behind em.
Thanks guys Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #856687 18th Sep 2020 5:59pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
They look similar to this one
PRC3180
Also used for the bonnet strut catch thing Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #856690 18th Sep 2020 6:05pm
Gloucesternige
No, not that one.
There are 3 different clips here. I searched around and couldn’t find clips that look like these??
I actually do need A PRC 3180 as it happens!! Nige
Post #856691 18th Sep 2020 6:14pm
The one that is the most numerous in your picture is NTC9543:
https://www.lrworkshop.com/parts/NTC9543L
At least some of the other ones appear to be on this page but some don't have pictures attached so you'd have to do a bit more research to pin them down precisely:
https://www.lrworkshop.com/diagrams/land-r...hers_44776
For a lot of this stuff, www.lrworkshop.com is your friend. Darren
Post #856698 18th Sep 2020 7:13pm
Martin
Site Admin
The double on the left might be NTC1177  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #856705 18th Sep 2020 7:50pm
Gloucesternige
Thanks very much. I get a little scared these days by websites selling bits like these when they state,"Image may not represent actual part" and so on... looks like you found the main one though.. thanks very much!! Nige
Post #856706 18th Sep 2020 7:52pm
MK
brake clip. Where does it go?
A bit of help needed.
Please look at the images. They belong to a LHD 2.2 110" non ABS. I am trying to figure out where this clip is attached. OPtion 1 is a stud located at the bulkead, option 2) maybe along with the bolt securing the expnasion tank and 3) further down in the bulheadwhere there is a hole passing through the foot area.
Thx
 Puma 110" SW
Post #980049 27th Jan 2023 4:56pm
MK
Thx
 Puma 110" SW
Post #980050 27th Jan 2023 4:57pm
