![]() | Home > Puma (Tdci) > Chassis clip help please. |
| Gloucesternige Member Since: 17 Jan 2020 Location: In the garage Posts: 114
Hi everyone.
I have finally got my 2011 chassis blasted and painted so reassembly can start soon. I wonder if anyone can help please with part numbers for these plastic clips which locate brake lines and breather lines to the chassis. They are hard and brittle so break when removed as you can’t get behind em.
Thanks guys Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
| Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 845
They look similar to this one
PRC3180 Also used for the bonnet strut catch thing Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
No, not that one.
There are 3 different clips here. I searched around and couldn’t find clips that look like these?? I actually do need A PRC 3180 as it happens!! Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
The one that is the most numerous in your picture is NTC9543:
https://www.lrworkshop.com/parts/NTC9543L At least some of the other ones appear to be on this page but some don't have pictures attached so you'd have to do a bit more research to pin them down precisely: https://www.lrworkshop.com/diagrams/land-r...hers_44776 For a lot of this stuff, www.lrworkshop.com is your friend. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
The double on the left might be NTC1177
1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanks very much. I get a little scared these days by websites selling bits like these when they state,"Image may not represent actual part" and so on... looks like you found the main one though.. thanks very much!! Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2510
A bit of help needed.
Please look at the images. They belong to a LHD 2.2 110" non ABS. I am trying to figure out where this clip is attached. OPtion 1 is a stud located at the bulkead, option 2) maybe along with the bolt securing the expnasion tank and 3) further down in the bulheadwhere there is a hole passing through the foot area. Thx Click image to enlarge Click image to enlarge Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
