Home > Technical > Glow plug 60a fuse blowing
chrisc2306
Scotland 2011 Defender 90 Puma 2.4 CSW Zambezi Silver
Looking for some advice on what could be going wrong with my puma. The 60a fuse under the drivers seat for the glow plugs keeps blowing as soon as I turn the ignition on, I've had a good look in the engine bay and can't seem to see any damaged cables. Anyone got any advice where to start? Is it a case of replacing the glow plugs? Glow plug relay? Its driving me mad trying to figure out what is wrong
Post #854792 7th Sep 2020 7:47pm
MadTom
First disconect the wire from glow plugs and switch on ignition. If the fuse survives, your problem is probably in glow plugs, it it burns again, look for short to ground (chassis). 60A is big fuse and needs proper short to burn. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #854867 8th Sep 2020 6:47am
chrisc2306
Does anyone know what route the black and yellow wire out of the glow plug relay takes to get to the glow plugs just so I can try and trace it and look for damage
Post #855144 9th Sep 2020 11:14am
leunknow
France 2006 Defender 130 Td5 HCPU Tonga Green
follow the tube on the side of the engine but easier with manifold removed
Post #857455 22nd Sep 2020 5:08pm
chrisc2306
I got it sorted it turned out to be one of the glow plugs that was shorting and blowing the fuse, all of them came out fairly easily which was a relief. The bolt holding the cable that feeds the glow plugs down was missing so I replaced that while I was at it I’ve read on some other posts that that has been the problem
Post #857463 22nd Sep 2020 5:33pm
hank
Glad to hear the plugs came out ok as I’ve read they can be a pig! > 110 XS Double Cab
Post #857466 22nd Sep 2020 6:04pm
