Home > Technical > Glow plug 60a fuse blowing |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 570 |
First disconect the wire from glow plugs and switch on ignition. If the fuse survives, your problem is probably in glow plugs, it it burns again, look for short to ground (chassis). 60A is big fuse and needs proper short to burn. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
8th Sep 2020 6:47am |
chrisc2306 Member Since: 02 Jan 2020 Location: Glasgow Posts: 58 |
Does anyone know what route the black and yellow wire out of the glow plug relay takes to get to the glow plugs just so I can try and trace it and look for damage
9th Sep 2020 11:14am |
leunknow Member Since: 22 Sep 2020 Location: Paris Posts: 3 |
follow the tube on the side of the engine but easier with manifold removed
22nd Sep 2020 5:08pm |
I got it sorted it turned out to be one of the glow plugs that was shorting and blowing the fuse, all of them came out fairly easily which was a relief. The bolt holding the cable that feeds the glow plugs down was missing so I replaced that while I was at it I’ve read on some other posts that that has been the problem
22nd Sep 2020 5:33pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2224 |
Glad to hear the plugs came out ok as I’ve read they can be a pig! > 110 XS Double Cab
> Instagram @simonlanemind |
22nd Sep 2020 6:04pm |
