Home > Maintenance & Modifications > What pretty bolts are these?
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
Any idea what bolts Retroworks Scotland have used in this photo below:
I've messaged them on Instagram but not had a reply Sad
Post #852616 28th Aug 2020 1:34pm
markb110
Hand painted after fitting, thinking that if they were anodised the coating could get damaged when tightening them down.
Why does it look as if they have painted the pedals with copper grease......
I am sure someone will have a better idea.....
Post #852619 28th Aug 2020 1:45pm
Bluest
I can't see what's unusual, but I have got crap eyesight. From here they just look like regular hex head bolts, maybe some of the them are flanged. 2007 110 TDCi Station Wagon XS
Post #852620 28th Aug 2020 1:48pm
discomog
I guess you are asking about the finish. If so they look to be either electroless nickel plated or cadmium plated, although hard to tell from the low res photo. You could even colour match to your vehicle colour if you wish with something like Xylan or any other fluoropolymer coating. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #852623 28th Aug 2020 1:56pm
rallysteve
Nothing special. Bright Zinc Plated with gold passivisation applied after plating. 02' 110 TD5 Double Cab Rebuild Thread
Post #852626 28th Aug 2020 2:03pm
As per post above, gold (or yellow) passivate finish. The bolts/setscrews on the vertical face and upper panel seem to be hex flange head, the ones on the toe-plate look to be hex socket button head.
Post #852629 28th Aug 2020 2:12pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Post #852630 28th Aug 2020 2:21pm
Woody3
Haha, I thought it looked like copperslip on the pedals too!
I should have been clearer in the OP - it is the finish I was querying. On the high Res photo it looks more of a copper finish as opposed to the standard zinc coating you can get. I'll have a look into the other finishes mentioned.
If you follow this link and swipe across a clearer photo can be found:
https://www.instagram.com/p/CEUlb-xsD7y/?igshid=5t2hwm5m9zra
ETA: someone has mentioned in the comments about 'yellow galvanised bolts'
Post #852655 28th Aug 2020 4:31pm
They must be expensive if they can't afford to put bolts in all the floor plate holes. 😜
If you want fancy bolts in fancy colours, these guys will help you:
https://www.pro-bolt.com/titanium/
25% off this weekend
Post #852679 28th Aug 2020 5:39pm
Mo Murphy
I doubt they're copper plated. It doesn't last long unless you lacquer it to protect from tarnishing.
Looks like zinc and yellow passivate to me.
50 Shades of Pennine Grey
Post #852708 28th Aug 2020 7:12pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
YZP (yellow zinc plated) bolts can be bought from decent bolt suppliers or you can send new or cleaned and polished old bolts to places like this http://daventrymf.co.uk/ who will apply a yellow passivated finish for you.
Restorers like Falcon Design Germany are using it a lot now on all different parts. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #852722 28th Aug 2020 8:14pm
