Home > Td5 > Central locking barrel |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
Behind the dash binnacle there should be a paper tag tied on to your ignition key barrel. With that number you can get what you need from JLR (supposedly) 🤷♂️
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
25th Aug 2020 2:41pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
The key number is also sometime recorded on a tag attached to the keyfob, but if the vehicle was preowned it probably isn't there any more. A good automotive locksmith (if you can find one) should be able to re-tumbler the lock to suit a particular key, this isn't difficult but you need access to supply of tumblers.
25th Aug 2020 7:14pm |
