Home > Maintenance & Modifications > Anybody know the part number for the washer
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
So from this picture,
below the reversing light there are two bolts that connect the body tub to the cross member. There is a t40 bolt thats a m8 form memory, but there is also a washer, does anybody know the washer part number? I know most people change to stainless fittings, but at present I just want to replace this bolt with the factory one (as mine has one bolt missing) the local LR garage has found the bolt part number and ordered it, but they can not locate the washer part number.
Can anybody help? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #851655 24th Aug 2020 8:23am
I can't help with the part number, although I suspect you can find it on Land Rover Workshop. However, if that picture is your Defender then I don't think they're the original bolts and washers anyway. The original washers are quite large, around 20mm in diameter, and the bolts have a chunkier head than what your picture appears to show.
This picture shows the originals (bottom) against some stainless ones that I replaced then with, all M8:
 Darren
Post #851656 24th Aug 2020 8:47am
Race.it
thanks, the photo is one I borrowed from the internet Smile
Not my vehicle, dont have one of my car with the missing bolt.
Its the original washer that I was trying to locate, on LR workshop I could not locate it, I found the bolt, but according to that there is no washer present (but there is I can see it on all the other bolts Smile) Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #851657 24th Aug 2020 8:51am
Hmm, ok. You're right in that LRW isn't immediately clear but a quick trawl through the diagrams suggests it's WA108056. Darren
Post #851662 24th Aug 2020 9:10am
rallysteve
LRW shows it as a spring washer... 02' 110 TD5 Double Cab Rebuild Thread
Post #851664 24th Aug 2020 9:13am
LRW is confusing on this one as the diagrams aren't very consistent in this area, but WA108056 is definitely a flat washer:
https://www.lrworkshop.com/parts/WA108056 Darren
Post #851668 24th Aug 2020 9:35am
Race.it
lets see what I get now with that part number, I have ordered these two in the past
WA108051 Plain Washer - M8 - WA108051
WL600051L Washer - Spring - WL600051L - Genuine
Both were not what I needed, so now to try WA108056 Smile Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #851669 24th Aug 2020 9:44am
Is it item 15 here?
detailed as:
Washer, M8, sprung - WL108007L
or also Washer, retaining WF600051L that goes on Screw M8 x 25, Torx drive.
Post #851670 24th Aug 2020 9:45am
Race.it
Lets see when it arrives Smile Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #851671 24th Aug 2020 9:46am
Martin
Site Admin
Maybe LR044352 - these are the ones used on the front bumper bolts. Measure and check?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #851679 24th Aug 2020 11:29am
I think the bumper bolts are M10 Confused Darren
Post #851681 24th Aug 2020 11:43am
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
It's one of those annoying inaccuracies with the LR diagrams. Indeed it is not a "star lock washer" as the diagram states. It's a Puma diagram but the nut plate and rivets are shown for earlier vehicles; it's just a copy/paste from the pre-Puma diagram.
I concur WA108056 is probably the one (M8 x 20mm diameter). Let me know if what you order is correct, then I will update the diagram(s). LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #851811 24th Aug 2020 10:14pm
Race.it
Thanks all, have it on order when I get it I’ll post photos etc 😎 Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #851827 25th Aug 2020 7:14am
Race.it
So this is the origional
This is the part number that was mentioned above fitted to the bolt
And the bolt started to be inserted
I think the search goes on, looks to be still larger in size and also thicker. Now question is do I bother keep buying random washers or go for a replacement set of stainless, new washers and some material in the middle of washer and bodywork to isolate it.
What are the best kits for stainless? I guess anodized won’t hold up that well. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #853364 31st Aug 2020 4:17pm
Race.it
Though looking at the photo maybe the bolt is wrong, have been fixating on the washer... Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #853366 31st Aug 2020 4:18pm
