![]() | Home > Maintenance & Modifications > Anybody know the part number for the washer |
I think the bolt on the left is the wrong one.
If it were me, I'd just replace the lot with stainless. There's no such thing as a 'best kit' for this. They are merely M8 x 25 bolts. Choose the head that type that takes your fancy (hex, cap head, torx, etc), add a stainless washer and a matching nylon washer to separate the stainless from the ali bodywork and job done. ![]() Click image to enlarge As an aside, I wouldn't actually recommend a regular hex head bolt for this application as there's more chance of damaging the paintwork. Choose an Allen or torx head type instead. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 227 ![]() ![]() ![]() |
Thanks for confirming - the washer looks right (even if the bolt doesn't). I've modified the diagrams to remove the pre-98 tab arrangement and to show the correct washers
![]() https://www.lrworkshop.com/diagrams/land-r...s_44853#18 https://www.lrworkshop.com/diagrams/land-r...s_44850#15 https://www.lrworkshop.com/diagrams/land-r...s_44851#10 LR Workshop New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
