Home > In Car Electronics > Identify plastic wiring clip from photo?
Gasket
Hi everyone. Could anyone identify the correct part number (or tell me the name of the generic part) of this wiring clip? I know we have a few electrical specialists so thought someone may recognise it by sight.
I’ve searched through microcat and have googled every iteration of “plastic c-clamp wiring clip” but just can’t find anything similar.
It’s nothing that couldn’t be replaced with a cable tie, but I’m a loon when it comes to refitting standard parts.
There’s three of them fitted to the Bluetooth microphone cable.
Thank you.
Post #850817 18th Aug 2020 10:56pm
PaulMc
That type of pipe clip usually comes as two parts -
Your larger one is a 90° clip
Your smaller one is a straight clip
They're both available as male (stud) or female (socket).
You will need a male and female, straight and 90°, to clip together to make the clip you need.
Measure the diameters and see which of these suit -
https://www.comdir.co.uk/push-in-swivel-ca...aight.html
https://www.comdir.co.uk/pushin-swivel-cab...aight.html
https://www.comdir.co.uk/push-in-swivel-ca...0-deg.html
Hellermann-Tyton also make them -
Unfortunately, all of the above are in lots of 100 Sad
. Paul.
Post #850831 19th Aug 2020 2:20am
Gasket
Paul - that’s amazing. Thank you: I’ll have a good google to see if I can find anyone selling in smaller quantities.
Post #850832 19th Aug 2020 2:34am
Gasket
Failing that it’ll be a cable tie loop with a second wrapped around the middle to form an “8”.
Post #850833 19th Aug 2020 2:38am
Gasket
Cable ties it is: they don’t seem to be available in small quantities. Thanks again Paul - that was a head scratcher. I’ve just posted a clean thread to ask about cable routing and where the three clips are located/what they’re attached to so I can recreate the position with ties.
Post #850837 19th Aug 2020 3:07am
