Home > In Car Electronics > Identify plastic wiring clip from photo? |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 486 |
That type of pipe clip usually comes as two parts -
Your larger one is a 90° clip Your smaller one is a straight clip They're both available as male (stud) or female (socket). You will need a male and female, straight and 90°, to clip together to make the clip you need. Measure the diameters and see which of these suit - https://www.comdir.co.uk/push-in-swivel-ca...aight.html https://www.comdir.co.uk/pushin-swivel-cab...aight.html https://www.comdir.co.uk/push-in-swivel-ca...0-deg.html https://www.comdir.co.uk/push-in-swivel-ca...0-deg.html Hellermann-Tyton also make them - Click image to enlarge Unfortunately, all of the above are in lots of 100 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
19th Aug 2020 2:20am |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Paul - that’s amazing. Thank you: I’ll have a good google to see if I can find anyone selling in smaller quantities.
19th Aug 2020 2:34am |
Failing that it’ll be a cable tie loop with a second wrapped around the middle to form an “8”.
19th Aug 2020 2:38am |
Cable ties it is: they don’t seem to be available in small quantities. Thanks again Paul - that was a head scratcher. I’ve just posted a clean thread to ask about cable routing and where the three clips are located/what they’re attached to so I can recreate the position with ties.
19th Aug 2020 3:07am |
